TwinTurbo.NET: Nissan 300ZX forum - I had a problem with the differential plug on my Infiniti.
not4resaleZ
on July 20, 2015 at 11:59 AM
Trans Fill Plug Stuck
posted by WE350Z
on July 20, 2015 at 03:00 AM
There was enough sticking out to put a pipe wrench on it.
WE350Z
03:00:15 07/20/15
Re: Trans Fill Plug Stuck
MaxxAction
07:42:52 07/20/15
Yeah I would also suggest not using a torque wrench
-Grimm-
09:39:50 07/20/15
Also
-Grimm-
09:41:29 07/20/15
I had a problem with the differential plug on my Infiniti. -
not4resaleZ
11:59:03 07/20/15
pipe wrench won't work these are 13mm hex bit (n/m)
WE350Z
14:53:09 07/20/15
Mine took a 13mm square bit. It was too hard
not4resaleZ
18:25:06 07/20/15
Dang - $30 bones for a socket! >>
WE350Z
18:50:15 07/20/15
That won't work. Need Square. I think I rounded mine
not4resaleZ
11:44:14 07/21/15
So I need to buy the $30 socket or risk rounding it with the
WE350Z
12:23:30 07/21/15
You can try the 1/2" but you do risk rounding it out.
not4resaleZ
13:06:54 07/21/15
Thanks was wondering where to apply the heat, as for the >>
WE350Z
17:37:07 07/21/15
If it's beat up, get a new plug. I'd just torque to spec. (n/m)
not4resaleZ
17:30:43 07/22/15
got it - i think mine is OK but I'll see how it looks after>
WE350Z
14:36:10 07/24/15
I had no idea there was a socket for that
ZXRider
13:27:02 07/23/15
yeah - 1/2" drive works out to 12.6mm which is not correct >
WE350Z
14:35:27 07/24/15
Thanks for the input guys >>
WE350Z
14:18:01 07/20/15
I've had to use a floor jack handle with my breaker bar once
Polish
00:02:37 07/21/15
Left loosy! (n/m)
WE350Z
12:19:34 07/21/15
I'm hoping i can get my breaker bar on enough of an angle >
WE350Z
14:42:44 07/24/15
